RGB Vs RGBS
Discussion in 'Cables & Switches' started by LiquidTV, Oct 24, 2004.
  1. LiquidTV
    LiquidTV
    Sep 24, 2004
    169
    Cornwall
    Okay, the LCD arrived a few days ago & have to say it's absolutely awesome.
    However, before I buy the necessary leads, it has as array of connections which includes two scart sockets one of which is RGB enabled.
    I have bought a RGBS scart apaptor to plug into the back of the LCD but do I actually need a RGBS lead to conect from sky or will a normal RGB lead suffice??
    Is there any difference in quality??
    These are £50 so want to enusre I buy the right one & not waste any money.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,474
    Rainham Essex
    +2,480
    The problem with trying to answer this question is that RGB is a generic term, ie there are several versions of RGB.
    A scart lead will carry RGB as RGBS (sync on composite) but there is also RGsB & RGBHV. So an RGB cable can be between 3, 4 & 5 cables. For your RGBS scart converter you need a 4 phono lead. As long as it has the 4 phono connections then it will work, 5 is also ok but 1 of them will not be used, 3 will not work.
    So to sum it up - if the RGB cable has 4 or 5 leads then it will work fine. However if it only has 3 leads then it wont work via scart.
    Mark.
  3. LiquidTV
    LiquidTV
    Sep 24, 2004
    169
    Cornwall
    Thanks Mark, I'll go ahead and order. Much appreciated.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  5. LiquidTV
    LiquidTV
    Sep 24, 2004
    169
    Cornwall
    Hornydragon, cheers mate. However, I needed a 10m long cable so on the advice of MarkE19 bought a Profigold PGV7410 RGBS cable. I then bought a Scart to four phono plug adaptor wired for RGB plus switchable composite in/out from Keene [KA150S]. I hope it will work!!
