RGB vs Prog Scan - which is best
Discussion in 'Blu-ray & DVD Players & Recorders' started by amar_fiaz, Nov 10, 2003.
  1. amar_fiaz
    amar_fiaz
    Hello Everyone,
    I be grateful for your comments about how to best connect my DVD to my plasma to achieve the best possible picture.
    I've recently upgraded my AV kit and bought the Sony DVPNS703 DVD player, mainly because it offers PAL prog scan. Now i connect the Sony to my Panasonic TH42PW5B pasma using component connections (3 wires colored red, green and blue). On the Sony setup it allows me to select the output as either video, s-video or RGB.
    Unfortunately, selecting the RGB option means that prog scan is not available. My question therefore is which option should i go for to get the best possible picture??
    1. DVD (video.s-video and prog scan) --> Plasma (component)
    2. DVD (RGB, no prog scan) --> Plasma (RGB)
    I'd appreciate any comments and advice.
    Thanks,
    AMAR
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,260
    Rainham Essex
    +2,403
    Unless either the DVD or plasma have a problem displaying a prog scan component picture then you should stick to the prog scan as that is the native format of the picture on a DVD disk and also of most plasma screens.
    Mark.
  3. amar_fiaz
    amar_fiaz
    Thanks for getting back to me Mark. So are you saying prog scan is always better than RGB (and are they always mutually exclusive)?? If so, am i doing the right thing by setting up my system like this:
    DVD (ouput signal: s-video) --> plasma (set to receive component signals).
    It just disturbs me a little to think i'm sending a s-video signal (via RGB component leads) to my plasma, when RGB is available. Am i missing the point somewhere along the line??
    AMAR
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,260
    Rainham Essex
    +2,403
    Prog scan is always better than RGB as long as the equipment used can display a prog scan image. Not all plasmas can and many DVD's can't, especially PAL prog as it has only recently be authorised.
    They are mutually exclusive as the component outputs on the DVD can send either component or RGB. That is why you set the output to S-Video or composite to get a prog scan image via component and would get no image if the plasma was set to component and the DVD to RGB.
    RGB can only transmit an interlaced image and a progressive scan image can only be transferred via a component connection.
    Mark.
  5. amar_fiaz
    amar_fiaz
    Thanks Mark. You've cleared up a lot of confusion for me, i appreciate the advice.
    AMAR
    Denon AVR1603
    Sony DVPNS730
    Panasonic TH42PW5
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,260
    Rainham Essex
    +2,403
    Glad to be of some help.
    It's not that long ago that I was the one asking the questions and trying to do the impossible. So now I'm just passing on some of the knowledge I have gained on these forums.
    Mark.
  7. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,516
    Kent
    +830
    RGB and Component
    - both of similar quality (want to say identical but they are different and people will only moan!)
    - both can be interlaced or progressive
    - RGB can exist as RGB with a H & V sync (the connection between your graphics card and PC is a non-interlaced RGBHV signal), RGB sync on black (what comes out an RGB scart socket), and RGB with sync on green (rarer than the other two)
    Then S-Video
    - IIRC created or co-created by BBC R&D team
    - same princibles as Component (break picture into luminance and chrominance) but cheaper than RGB which at the time was v.expensive
    Lastly Composite Video
    -absolute pants but you could run a cable to the moon and back and still get a picture!
    Prog Scan
    this is the process of sending a de-interlaced signal from source to display. It can run either over RGB or component but is generally run over component in consumer electronics.
    The confusing bit
    the DVD player will usually have a output signal selection (VIDEO, SVIDEO, or RGB) which relates to the scart socket only. As component is separate to this output it will often work regardless (although usually activating RGB or SVIDEO will kill the component output). So all along you were sending component out, at the same time your scart socket was pushing out svideo too...
  8. Bassline@ddict
    Bassline@ddict
    Dec 20, 2002
    453
    West Sussex
    +14
    Excellent explanation!
    :clap: :clap: :clap:
  9. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Should we also mention that RGB is technically actually better than YUV (Component) but it's of no use since the information on the DVD disc itself is stored in YUV format?
    YUV has a limited color space as compared to RGB, but of course conversion from YUV to RGB (which is AFAIK lossless) doesn't 'improve' it. Then again YUV is obviously good enough ...
  10. amar_fiaz
    amar_fiaz
    Thanks to everyone for their comments. Based on Liam's explanation i'm pretty certain that i've setup my hardware to achieve the best possible picture.
    Connecting my DVD to plasma via component should be sending progressive scan signals. Therefore displaying the best possible picture
    Thanks again,
    AMAR
  11. mikeq
    mikeq
    You can check which signal your plasma is receiving through the hidden service menu, look for the thread in this forum.
    Mike
  12. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    Seems to me that the definitive answer is:
    DVD to Plasma using component AND prog scan will give you the best possible picture from your options.
  13. John Narayan
    John Narayan
    Yea but all TV'S convert to R.G.B anyhow, all things being
    equal it should not matter:- unless you want progressive
    scan (non-interlaced) use component.
