rgb vs component
Discussion in 'Satellite TV, Sky TV & FreeSat' started by szgo, Sep 12, 2003.
  1. szgo
    szgo
    Got a problem I would like to run by you guys; I have the Tosh 32ZD26 which has component inputs and scart rgb. I have an ntsc games console which I was using component and enjoying prog scan but now I have a jvc dvd player which has component outputs and delivers a pretty impressive image through them. I don't want to keep swapping the component cables over between the console and the dvd so my question was whether I will get anywhere near component quality if I use a good quality rgb scart cable? Thanks!
  2. Jsinger
    Jsinger
    Aug 26, 2003
    40
    Unless you're aiming to run a progressive scan feed through the RGB scart, the simple answer is that you're highly unlikely to notice any real difference.
  3. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    I find the rgb scart & component inputs on my zd26p are both superb quality. I only use component because I can !:)
  4. szgo
    szgo
    Thanks for the swift reply, what should I look for in scart cable? and idea of price?
  5. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Make sure it is fully screened and gold plugs are preferable.
