RGB vs component on toshiba WL56 series
Discussion in 'LCD & LED LCD TVs Forum' started by av_master, Aug 31, 2005.
Tags:
  1. av_master
    av_master
    Just wondering if anyone has compared RGB scart with component progressive scan signal coming from a DVD player on this set. Is there any difference at all? (i.e. perhaps the tv's deinterlacer does just as well as the DVD player's?)
    Since the tv takes component through the VGA input it'd be really irritating to use both a DVD player with progressive and a PC because you'd have to unplug/replug the vga lead every time you switch devices. And the audio connection. So I was thinking of simply using a dvd player with an rgb scart connection so I can leave the pc plugged in all the time.
    Any feedback greatly appreciated!
