RGB via Scart to HS50?
Discussion in 'Cables & Switches' started by sapkan, Oct 25, 2004.
  1. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    I am planning a home cinema setup from scratch and want to make sure I get the connections just right. I have a Philips sattelite receiver that has two scarts as well as composite. I want to connect it to a Sony PJ possibly the hs50 and to a smaller LCD.
    Sattelite box outputs:
    TV Scart- supports RGB dont know about S-Video
    Video Scart- dont know whats it for
    Composite- yellow cinch
    I have also planned a Yamaha 1500/2500 type receiver.
    I want to use the RGB Scart as to get the best PQ but neither the receiver nor the PJ have scart inputs. What do I do?
  2. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
  3. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    No, that cable is for boxes that can output component over a scart connector (such as a Netgem iPlayer freeview box).
    You'll need something like the JS Scart2RGB convertor, which will actually convert your SCART RGB to component. JS are a forum sponsor - check out their homepage.
  4. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    ...really boring the way receivers dont have scart ins....
  5. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    I presume that the composite to component upconversion that amps of recent feature is simply a convenience feature and does not improve quality. Am I right?
    In that respect would using RGB to Component (YUV) Video Converter (I presume that is what you meant) yield a better picture?
  6. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    Yes, pretty much just a convenience feature. RGB-YUV will almost certainly give a better result that converting the composite.
  7. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    Thought so...
    what about a way to output from the RGB Scart to both the PJ and LCD (not simultaneously) cause I dont want to use the composite. Is there such a thing as RGB Scart splitter 1 in---2 out
