RGB-VGA Input, or Scart on LG LCD?
Discussion in 'LCD & LED LCD TVs Forum' started by rorton, Dec 26, 2004.
Tags:
  1. rorton
    rorton
    Dec 26, 2004
    311
    28
    +30
    Hi All
    New to the forum, but would like some info if possible.
    I have a 22 " LG LCD TV, and at present, i have NTL Digital Cable, and a DVD Player Connected to it.
    The NTL Is connected via a Scart to the only scart socket on the set, and the DVD is connected to the S-Video input.
    The TV does have a 15 pin input (PC Style) and the manual says this is an RGB-PC Input.
    Im wondering if i will get any better picture quality, connecting the Cable TV box to the RGB-PC input using the RGB /Scart output on the cable box, and then the DVD Player to the Scart input, rather than the S-Video, OR, does any one know of a 'Breakout Box' type thing (the type you see sold with the Plasmas) which has a single connection to the LCD (using the RGB-PC vga connector) and then plug in the Cable Box/DVD and any other stuff i may want to plug in?
    Any ideas or suggestions please?
  2. Gman85
    Gman85
    Hi there, i would like some info about what your after if you get any!?
  3. rorton
    rorton
    Dec 26, 2004
    311
    28
    +30
    hi, dont understand what your asking saying (sorry) what do you mean by 'info about what im after if i get any??' Get any what?
