RGB > VGA Convertor
Discussion in 'Plasma TVs Forum' started by nheather, Nov 7, 2004.
  1. nheather
    nheather
    Oct 6, 2004
    18,639
    167
    Horsham, West Sussex
    +8,497
    Going to be buying a Pany PW7 very soon. All of my sources are SCART RGB and I will switch these through a Quintro.
    I have read it is better to process these through a JS RGB>VGA convertor. Since most of the deals I have seen come without a terminal board it looks like I would be best not bothering with a SCART terminal board at all and buying a JS Convertor instead.
    Does this make sound sense ?
    Is there anything I should be aware of if I go this route ?
    I'm already aware that I couldn't use a composite source (e.g. camera)
    I've also read that I would lose support for switching but I'm not really sure what it means and how important it is.
    Any advice welcome.
    Cheers,
    Nigel
  2. zedzed
    zedzed
    Jul 12, 2004
    821
    Linlithgow (nr. Edinburgh)
    +13
    I don't think switching is that important - but if you find that it really bugs you you can buy a device (bout £70 IIRC) that does it for u (when using VGA).
    The only downside of not having a board at all is that if you /do/ buy a device that needs to be configured before you use it (i.e. it doesn't output RGB as default) then you'll be snookered - as the VGA convertor will only pass through an RGB signal. The VGA input on the PW7 doesn't take component either - so you also can't configure any device that outputs component (PYbYr) as default either.
    IMHO it's worth buying the PW7 from a reputable dealer (av-sales spring to mind) who sell the panel with a "free" input board.
    ZedZed
