RGB to YUV problem
Discussion in 'Plasma TVs' started by bobo360m, Dec 22, 2003.
  1. bobo360m
    bobo360m
    Dec 9, 2003
    20
    wales
    I'm having a problem getting SKY to my Plasma.I've bought a JS Tech RGB to YUV convertor.Connected Scart to Scart from sky to convertor.Convertor is 3 phono to 3 bnc to rear of plasma but am geting no picture.The sky box is set to RGB output and not PAL.The plasma is Delphi DD42E.
  2. jont
    jont
    Apr 8, 2002
    3,938
    near Aylesbury
    +416
    Does the Delphi not take RGB in on the phonos not YUV - in which cas you just need an RGB scart to RGB phono adaptor/lead ??
    Jon
  3. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    I know you have set the Sky box to RGB, but remember that whenever you press the TV button on the Sky remote, the Sky box reverts to PAL (composite) output until you press the Sky button again. The only way to avoid this is to make sure that you cover the emitter at the top of the remote if you press TV.
    On a side note, if your plasma has a VGA input, I have a JS Tech RGB-to-VGA convertor, and would like to change to the version you have. If you decide this may be a better connection method, i would be very interested in an exchange, plus some cash to make up the difference of course. VGA is sharper than YUV, but on my Panasonic plasma I loose one of the widescreen modes.
