RGB to YPrPb de-interlacer
Discussion in 'Projectors, Screens & Video Processors' started by simoncope, Jul 22, 2004.
  1. simoncope
    simoncope
    Does anybody know of a de-interlacer that can take an RGB SCART input (say from a Sky digibox) and output a de-interlaced component video (YPrPb) signal? I'm looking for purely de-interlacing only (no scaling), as the signal will be then distributed to multiple display devices (with different resolutions, naturally!).
    Thanks!
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,058
    Simon,,,,,
    Lumagens do that......IscanHD's do that.....quite a few will do that.....
    Not sure what your displays are but if you give me a call I can try to give some advice.
    Gordon
  3. parky43007
    parky43007
    Oct 8, 2003
    235
    Tarragona
    +16
    The only one know with an actual scart input on the back is the cinemateq optimizer.
  4. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    Whether the scart connector is on the scaler is largely irrelivent, with most scalers you can use a scart to RGB CV (4 RCA) cable. The only real advantage with having a real scart socket on a scaler is aspect ratio detection.
