RGB to you projectors
Discussion in 'Projectors, Screens & Video Processors' started by leon, Dec 20, 2001.
  1. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
    could you tell me what component cables you use to your projectors and where did you get them from ....e.g vanden-hul/qed /?
  2. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
    help :):) :)
  3. jason t
    jason t
    Mar 4, 2001
    1,708
    48
    kent
    +38
  4. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
    only one reply :( :( :( :( :clown:
  5. AlfaKhan
    AlfaKhan
    Aug 7, 2001
    250
    Cascais, Portugal
    +6
  6. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    Portsmouth / Middle East
    +77
    I use chord component interconnects 3 x phono, custom built direct from Chord. Cost £140 for 4xmtrs.
    Very high quality lead with great playback!
  7. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Make sure it is 75 Ohm, rather than a tweako cable like Kimber, Chord, Van Den Hul. This is the most basic specification that needs to be addressed. Otherwise it will be an analogue cable rather than a digital / video one.
    I had a Chord XLR digital cable on test. The company supplied just the twisty £200 analogue cable as there premium balanced digital one. It was confortably bettered by the Maplin cable for £1.50 / m. The maplin was the correct 110 Ohm, the Chord wasn't. Guess which I kept.;)
  8. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    +77
    As these comments clearly prove you should try before you buy and find a cable that suits your eye and your system.
    Most good hifi/av outlets will let you try a cable out before you purchase, and if they don't then you can pop down to Woolworths or Maplins and buy a cheapo box set for £2.99 ;)
