rgb to vga versus component yuv
Discussion in 'General TV Discussions Forum' started by Splatt, Jun 3, 2002.
  1. Splatt
    Splatt
    have arcam dv27 connected to pioneer pdp502mxe with pda5002 video box via component video , would it be better picture with a rgb to vga converter(from rgbtosvideo.com £120)using the rgb output from the arcam to the vga connector on the pioneer
  2. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    John's convertor is a great box, but I'd be surprised if you saw much difference between component and RGB to VGA.
    Best image quality from the DV27 is going to come from PAL progressive via component I would have thought.
    If you are not sure how to enable PAL progressive take a look here :
    http://www.envytech.co.uk/dv88/
    Mark
