Rgb To Vga Js Tech Converter?
Discussion in 'Plasma TVs' started by usman24, Jul 20, 2005.
  1. usman24
    usman24
    Aug 3, 2004
    1,792
    41
    Birmingham
    +23
    I have just seen a rgb to vga converter developed by js tech. Is this better for picture quality than rgb to component converter [js tech] for connecting to a plasma screen?
    Any experience? Ideas?
  2. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    yes if you are using a plasma panel not tv.
  3. vileda
    vileda
    Oct 15, 2004
    401
    Sunderland, Tyne & Wear
    Is there really much difference between the JS RGB>VGA & the RGB>YUV?? in terms of pic quality?
  4. tamthetim
    tamthetim
    Nov 7, 2004
    478
    Perth
    +6
    Don't know but going to find out on Monday when Sky+ gets installed, previously had RGB to VGA with Sky...................................now putting everthing to my amp and one component cable to plasma.
    So bought a RGB to component converter in the classifieds.................don't think they'll be much diff..................................might also depend on the digibox i get.......................Amstrad :rolleyes: or Pace :smashin:
    Cheers,Tam
  5. vileda
    vileda
    Oct 15, 2004
    401
    Looking forward to hearing if there is a noticeable difference
  6. Piers
    Piers
    Dec 11, 2002
    1,973
    Shropshire
    +227
    It depends on which plasma screen you are using. Some (Sony in particular I seem to remember) don't work with the VGA converter. Those that can work with either the VGA or YUV converter - no colour saturation control with the VGA version, but usually available with the YUV one. Unlikely to be much of an issue IMHO but I know that another ISF calibrator might not agree with me on that point : ))
