RGB to VGA Box
Discussion in 'Projectors, Screens & Video Processors' started by Jonny1973, Feb 11, 2002.
  1. Jonny1973
    Jonny1973
    Can anyone recommend the RGB to Plasma VGA box from John Sim?
    www.rgbtosvideo.com
    I've just bought a Panasonic PT-AE100 and I'm looking for the best picture quality possible for both sky digital and dvd.
    I've tried component video (too soft), s-video (too harsh) and a HTPC (great). The PC won hands down but it would be more convenient to use a standard DVD player.
    I'm tempted to give a plasma vga box a go. I assume it would also work with a projector.
    Jonny
  2. calibos
    calibos
    Aug 4, 2000
    951
    Ireland
    +39
    I emailed John Sim this very question and here is his response:
    Dear Keith,
    I'm sorry but the RGB to Plasma VGA unit doesn't work too well with LCD data projectors. While with some you do get a picture, it's usually cropped. All PAL sized pictures are cropped to NTSC.
    Do you have component (YUV) input?
    All the best,
    John.
  3. Pip_UK
    Pip_UK
    Have a look in the TV forum. I asked a similar question regarding a digibox to PDP display (37" Panasonic)
    Have been advised to buy a RGB scart to 4 phonos (RGB via component and the fourth being a syn signal in the composite input). Not sure if your projector would accept this ... someone reading this may know.
    A forum member who replied to my post has used the RGB to VGA convertor and did not see any picture improvement of the above method on a PDP
    Pip
