RGB to S-video?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Ken, Feb 21, 2003.
  1. Ken
    Ken
    Dec 15, 2000
    362
    Stoke-on-Trent
    Is it possible to get s-video from the scart on a pace 1000 NTL cable STB? All I get is B $ W pictures.
    Ken
  2. nicropolis
    nicropolis
    I am not familiar with that particular STB, but I had the same problem with the RGB outlet on my Portuguese STB, until I used the second scart outlet, labelled VHS, when bingo! I got colour to the S-video input on my monitor.
    You may also need to change the menu setting on your STB from RGB to S-Video or S-VHS.
    Good luck
    Nick
  3. Ken
    Ken
    Dec 15, 2000
    362
    Stoke-on-Trent
    Thanks for the reply Nick, but I get the same result from both scarts and s-video is not an option in the control panel.
    ken
  4. JamesTapp
    JamesTapp
    Oct 2, 2002
    235
    16
    Bedfordshire
    Ken,
    Most STB only offer Composite or RGB output, not S-Video (Sky+ being the exception).
    You need a conversion box. IMO the best on the market is made by http://www.rgbtosvideo.com
    If you want to make sure you lose minimal quality in the conversion process JS Tech is the way to go. John Sim actually spends quite some time in the plasma forum, where his convertors are generally viewed as being second to none.
    Kind Regards,
    James
  5. Ken
    Ken
    Dec 15, 2000
    362
    Stoke-on-Trent
    Thanks James, I will investigate those options.
    ken
  6. jim.rae
    jim.rae
    Most gadgets will not putput RGB and S VHS together - it has to be selected from the set up menu - either one or the other...
