RGB to S-Video Converter question
Discussion in 'Projectors, Screens & Video Processors' started by wolfe, May 26, 2002.
  1. wolfe
    wolfe
    Which one do I order?
    The Jsvideo or the keene?
    Any good/bad experiences?
    This is to get my CATV box into my DSP-A5 then out to my HTPC then to my AE100...when it arrives:rolleyes:
    Your help and experiences are appreciated:blush:
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,467
    Norwich
    +949
    i have used the keene version and have to say the picture produced was far better than expected, however the image does shift over to the left about 8%.
    there is a small pot in side the unit that corrects this a little.
    this is fine and didnt annoy me to much but worth knowing.
  3. Hermie
    Hermie
    Jun 3, 2001
    3
    Suffolk
    I use the keene converter & have had no problems with it. However I do think it's a bit expensive for what it is !
    Hermie
  4. wolfe
    wolfe
    Any other opinions?
  5. stevenwilliams
    stevenwilliams
    Mar 17, 2002
    36
    Crawley, West sussex
    I have the JSvideo and Keene converters and am happy with both.
    I havn't had the screen shift problem with either.
    I just swapped them on my Pioneer 939-a DVD player and I would say the picture quality comming out of the JS version is slightly better but this may just be with my system.
    Have a look at the Lektropacks unit
    you can find it here
    http://www.lektropacks.co.uk/product/technical.asp?dept_id=103&sku=207
  6. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,467
    Norwich
    +949
    sorry it was the letropacks i bought in the end not the keene, the keene was out of stock at the time.
    so i guess you can count that one out as the others dont have the shift problem.
  7. bxd
    bxd
    Oct 17, 2001
    1,487
    Southampton
    +134
    I'd buy the JS one and support the sales (and the future) of a small producer who makes a range of high quality products.
    Brian
