Rgb To S-video/composite Converter
Discussion in 'Digital TV & Video Players & Recorders' started by micks_address, Sep 16, 2003.
Tags:
  1. micks_address
    micks_address
    Nov 29, 2001
    4,327
    83
    Dublin
    +172
    Hi folks,
    I need something like this
    http://www.lektropacks.co.uk/product/technical.asp?dept_id=103&sku=207
    to convert the rgb signal from my vcr's scart socket so that i can send it to the s-video connection on my Sony projector. I think this product will do the trick.. Thing is i'd like a cheaper solution. Anyone come across a product that does the conversion from rgb scart (which i'm assuming my vcr is outputting - can't find manul its a mitubishi black diamond) to s-video.
    I have a simple adapter at home which plugs into the scart socket and has an s-video connection but the resultant picture is in black and white. Any ideas appreciated
    Thanks,
    Mick
  2. DaveP
    DaveP
    I would be very surprised if your VCR had an RGB output, just because it's got a scart doesn't mean it has RGB.
    The reason you get black and white is probably because you are not outputting S-Video. Only S-VHS VCRs are capable of this.
    The best you can expect from a bog standard VCR is Composite output.
    This is just my view of course, I could be totally wrong!
    Dave
  3. micks_address
    micks_address
    Nov 29, 2001
    4,327
    83
    Dublin
    +172
    so what your saying is that i need a composite to s-video convertor?
    http://www.keene.co.uk/system/keene.htm
    link doesn't go to the product but the product code is STOC
    will something like the link above work - if i feed the composite from the vcr to that will the s-video the other side then be in colour?
    i want to use the s-video cable as it will avoid running another cable to the pj....
    Cheers.,
    Mick
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,107
    Rainham Essex
    +2,380
    The converter will work, but it will not improve the picture. It will still just be a composite signal, but sent as a compatable signal for S-Video.
    If as you say it is just to prevent you running another cable to the PJ then it will do the job and give a colour picture.
    Mark.
  5. micks_address
    micks_address
    Nov 29, 2001
    4,327
    83
    Dublin
    +172
    Thanks Mark,
    I ordered it from Keene so hopefully i'll have it by the end of the week. I have enough cables running through the place already. My other half wouldn't welcome another one. I'm not overly fused about picture quality as i'll just be using it to view some Terrestrial channels via rf feed.
    Cheers,
    Mick
