RGB to Plasma VGA - HELP! (PW6)
Discussion in 'Plasma TVs Forum' started by KEVO.S, Jan 29, 2005.
  1. KEVO.S
    KEVO.S
    Dec 31, 2004
    5
    Recently bought a Panasonic 42PWD6 plasma screen, started off with tech link scart to scart from DVD to Sky to Plasma worked quite well. Then bought a RGB to plasma VGA V.2 to improve picture. Have connected :- DVD to Sky with scart, Sky to RGB to Plasma box with scart and VGA to VGA from box to Plasma screen. At which point i get a 'no signal' message on screen!!!
    Have tried to set it to RGB but still no joy.
    Any suggestion or ideas where i'm going wrong!!
    Could VGA cable be faulty or am i missing something!!
    Kevo
    :lease:
  2. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    are you remembering to press the input button on plasma remote................................to change to PC?
    cheers,tam
  3. rhodos
    rhodos
    Oct 3, 2004
    1,640
    63
    Wirral
    +151
    Sky definitely set to RGB also?
    If it was composite then would have worked OK via scart board on PW as it takes RGB and composite but It HAS TO BE RGB ON SKY to get thru on VGA in the set up you have.
  4. KEVO.S
    KEVO.S
    Dec 31, 2004
    5
    Thanks Tam but did that.
    Thanks Banjo but sky was set to RGB but still no picture!!
    Any more ideas!!
  5. rhodos
    rhodos
    Oct 3, 2004
    1,640
    63
    Wirral
    +151
    Have u tried just DVD thru JS to Plasma and ditto for Sky. I have same setup on PW7 and works fine. Could you try a laptop/PC direct into VGA port - that will at least prove VGA socket OK.
