Rgb To Pioneer Xde Help
Discussion in 'Plasma TVs Forum' started by rufus, Jan 23, 2005.
  1. rufus
    rufus
    Dec 5, 2004
    :lease: Please Could Some One Help Me?
    I Am Trying To Put My Sky + To My Pio 435 Xde Through A Rgb Ixos Xhv601 Lead. But When I Set The Pio To Input 1 & Rgb Input On Options menu ,I Get No Picture Or Sound . Sky Is Set To Rgb Output.
    The Only Way I Can Seem To Get A Picture Is With Pio Set To Video instead of rgb on the Options menu . The Info On Screen Says Video & Pal When Changing To Input 1
  2. scrowe
    scrowe
    Jan 8, 2005
    1,104
    116
    Brighton
    +638
    Best guess is that your scart lead is not fully wired, with only the AV pins wired. Try another scart lead?
    Later Edit:
    You say you're using a HQ RGB scart, so should be OK, but perhaps it's faulty?
    I'd try another scart lead to be sure, even a cheap one.
  3. rufus
    rufus
    Dec 5, 2004
    Hi scrowe,
    have just put the standard supplied scart lead in, have sound now but still no picture with settings to rgb.
  4. scrowe
    scrowe
    Jan 8, 2005
    1,104
    116
    Brighton
    +638
    Are you sure your scarts are seated properly? You sometimes need a sedgehammer (not literally but YKWIM) approach to get them to seat squarely in the socket. Also check for broken/bent pins in the scart leads.
  5. rufus
    rufus
    Dec 5, 2004
    but if it was a problem with the scart would'nt it have the same effect with the pio set to video instead of rgb input on the options menu ?
  6. scrowe
    scrowe
    Jan 8, 2005
    1,104
    116
    Brighton
    +638
    AIUI, each pin carries a seperate signal, so if it's possible if a scart is not seated or has faulty pins, to get video w/o audio, and vice-versa, also green/red/blue pictures and so forth.
