RGB to Panasonic V6 Component/RGB board
Discussion in 'Plasma TVs' started by TerryJones, Nov 30, 2003.
  1. TerryJones
    TerryJones
    Nov 30, 2003
    9
    This weekend I have installed my Panny V6 (I have the 'commercial' charcoal version).
    It shipped with the dual Composite/SVID : Component/RGB board (BNC connectors for RGB).
    My main sources are Panny DMR-E20 DVD recorder and Panny Sky box.
    I have routed the RGB signals from the sources through a Trilogy SCART switcher then have a SCART to RGB+composite cable to the plasma but have found that this setup does not work with a V6 panel (even though he s/w lets you set it up???) .
    As composite from the Sky box was so bright it nearly blinded us (even with contrast and brightness set to minimum) and poor quality I attached the DVD recorder to SVIDEO using a lead I had and found (to my surprise) that it routes and converts the RGB coming in from my SKY box (via the Trilogy) to SVideo and the results are great quality (I know RGB would be better but needs as must for the time being).
    Now I need to sort out something permanent.
    As I see it my options are (I want to save the VGA port for computer use):
    1 Replace the SCART-RGB cable with a Syncblaster RGB+HSync/VSync cable (c. £75)
    2 Replace the SCART-RGB cable with RGB->Component convertor and component cable (c. £150+vat)
    3 Buy a SCART board for the plasma. (£135+vat)
    So, is anyone else using any of the above?
    Thanks,
    Terry
  2. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    Since you wish to keep the VGA input for PC use (and why not?), then the only real option is to convert the RGB signal to Component video. Which is why I designed such a converter!
    All the best,
    Dr John Sim.
  3. TerryJones
    TerryJones
    Nov 30, 2003
    9
    When I run out of slots I'll get one! For now I have taken the option of adding a SCART board to the display. I have a rather expensive RGB cable that is no longer required and can be returned so the cost of this option was the most attractive!
