RGB to Component
Discussion in 'Projectors, Screens & Video Processors' started by Malone, Apr 8, 2002.
  1. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    No doubt this has been approached before, anyway can you carry RGB through component leads or is there a RGB to Component converter. Short & Sweet......(obviously to a PJ)
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,159
    The Borders
    +3,376
    Hello Malone
    We sell the range of RGB to plasma interface boxes from John Sim at JS Technology and we will be adding in Johns new RGB to Component converter in the next couple of weeks when the first batch of products comes off the production line.
    I expect the price will be around £100 and up to the usual great standard that Johns products have become know for - John quite often posts here as Symanski; do a search and you will get an idea of where he is coming from.
    Best regards
    Joe
  3. Hellicopter
    Hellicopter
    Jan 26, 2002
    334
    +9
    Joe-any chance of checking whether John's RGB to Plasma VGA converter works on the Panasonic PT AE 100?
  4. Timh
    Timh
    Sep 14, 2000
    5,267
    3
    3
    Altair-4
    +339
    Joe
    I would also be interested in how the rgb/componant convertor works with the AE100.
    I cannot put up with composite from my set top box, it sucks.
  5. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    Cheers Joe, i'll keep my eyes open for any posts.
    May seem like a silly question because the source is RGB and not component but being that its a converter will you get RGB quality or Component. :blush: and how many inputs would this box have.
    Regards Matt
  6. Guest
    The RGB to plasma VGA convertor doesn't work with the AE100, at least it didn't when I tried it..
    Andy
  7. apexsec
    apexsec
    Straying from the point of RGB to Component slighty, what is the Synchblaster lead that Keene Electronics do that is supposed to convert a scart output to a svga input.
    Has anybody tried it and what are the results?
    I rang Keene on 08/04/02 to find out more info but was advised to talk to the guy that designed the lead but he wasn`t in, so will ring back 09/04/02 and will let you know.
  8. General Skanky
    General Skanky
    Jul 28, 2000
    4,252
    71
    Colchester
    +44
    The RGB to plasma won't work as it operates at a different frequency than the Ae100. I asked them direct for that one.
    I too am interested in a RGB to VGA convertor for my sky box. That would be good.
    I use a RGB to S Video convertor at the moment which is good. Cheers Retronana, [​IMG]
    But anything better I'm always interested in, as otherwise the next step is the IScan.
  9. Big Jim
    Big Jim
    I am in a similar situation, but the other way round - I have a TV that doea not display NTSC in colour, and a US gamecube that does not output in RGB.
    Is there a solution for component to RGB anywhere?
    Will John Sim's box do the conversion backwards as I need it?
  10. bxd
    bxd
    Oct 17, 2001
    1,487
    Southampton
    +134
    Jim,
    Key Digital do a box (the KD-CTC A2) which converts component to rgbhv. That might be suitable for your needs.
    As far as I can tell, the Keene device increases the sync voltage so that a projector can actually lock onto the signal via it's vga/rgbhv connectors (e.g my crt projector won't lock onto a scart derived rgb signal for this reason) However it all depends on whether the pj is actually capable of handling a 15kHz signal on the vga input.
    Brian
  11. apexsec
    apexsec
    THE SYNCBLASTER WONT DO THE JOB cos as has been previously suggested unless your projector will go to horizontal frequencies as low as 15Khz it wont see the input .
    As for the panny ae100 its horizontal frequencies start at 30 Khz.
    This is straight from the horses mouth .
    the designer at Keene.
    The next best thing is to wait for JS Technologies to finish their RGB to Component Converter, which after speaking to them today will be at least 2 weeks.
    Sorry folks.
  12. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    Just to re-iterate is the converter "upgrading" the quality of RGB to Component levels???
    Matt......
  13. apexsec
    apexsec
    When I rang JS Tech today I asked the same question.
    The answer was yes it would be a component grade signal.
    The answer I got was ` if you can imagine a graphlike scale composite would be at the bottom and there would be a great leap to s-vhs , from s-vhs to rgb there would be a small jump, from rgb to component there would be a very small step`
    If your equipment is of high enough quality to see this `very small step ` then you will benefit . But Yes it is a component signal.
  14. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    Cheers M'Dears
    Matt..............
  15. Big Jim
    Big Jim
    Ta Brian,
    I will have a look at that...
  16. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    has any one tried this rgb to component converter .if so is it worth buying
    i want to conect from sky to sony 11ht or to maybe go from dvd via denon amp component inputs then to PJ would this work
    [email protected]
