RGB to component ?
Discussion in 'Cables & Switches' started by awildman69, Aug 26, 2004.
  1. awildman69
    awildman69
    i have a sky+ hooked up to a logik lcx27wn2 lcd tv with scart and a tosh330 dvd with component, the tosh is v-good but the sky+ is not so.
    any one know if a scart RGB to component converter will improve this? :lease:
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,130
    Rainham Essex
    +2,392
    If you have Sky connected to the LCD with the scart socket outputting RGB then you will see very little, if any improvement IMO by converting the RGB to component.
    Unfortunatley most Sky channels are transmitted with a low bit rate and therefore there is very little you can do to improve the signal. If you have the budget you could put Sky (and DVD) through a video processor, but at £1000+ they are an expensive upgrade.
    Mark.
  3. newstuart
    newstuart
    Apr 22, 2004
    1,665
    Northumberland
    +59
    hi sorry to butt into your thread,
    im thinking of buying one of these for a bedroom set up, are they any good ? they do seem cheap for a 27" lcd
