RGB to Component losing sync!
Discussion in 'Plasma TVs' started by mpf2003, Nov 4, 2003.
  1. mpf2003
    mpf2003
    Apologies if this has been covered (i did search).
    I have a 30" LG LCD with component inputs. I bought an RGB to YUV converter for my sky+ box and connected everything up. Picture was very good but intermittently goes off!! The message 'No Signal' appears briefly and then the picture comes back. I thought it may have been the 'Widecsreen switching ' signal interfering but it still does it even with this turned off. The makers of the converter say that a poor satellite signal would cause the sync signal to miss and produce this problem but ive tried connecting a dvd player direct and the same thing happens.
    Any ideas?
    Thanks.
  2. ziocleto
    ziocleto
    I did have the same problem, not exactly the same but what it turned out to be was the telly that had a fault.
    Absolutely not sure this is your case anyway...
  3. deman77
    deman77
    Aug 20, 2003
    260
    16
    London
    I have had this problem on Q-sync extractor from QED. They describe it in troubleshooting saying that one probelm is the Vertical or Horizontal scan problem on the screen but that applies only ot 5% of the screens.
    What I found was my problem though was interference over the sync box power cable. I failed to identify what exactly was causing it. Most of the time moving my phone base a few inches helped. I couldn't be bothered to look what exactly it was as it is fine now.
    Try eliminating possible sources one by one and you will find what;s causing it
  4. stevehayles
    stevehayles
    INterseting post as I have exactly the same problems with my LG LCD panel
    I have had a Toshiba 520 dvd player for a while connected via high quality component video cables to an LG MW-30LZ10 30" lcd. The picture quality is definitely better with component than with anything else but intermittently I get a 'no signal' display on my panel and the image dissapears for a few seconds.
    I know that at least one other person has seen similar problems with the LG panel. Mine has been off for repair (which took a ridiculous three months to get returned from LG!!!) but they could find no fault.
    There is no repeatability to the problem it seems as I can replay a DVD that caused a problem and it will be fine. I have tried routing the cable away from everything else. The DVD player is multiregion bu I would have thought that should not be a problem. All the disc I have tried to date are R2.
    I get a similar problem feeding a component signal to the panel via a CSY2100 RGB>Component box but I now suspect that maybe the problems (despite ointing to the Panel) are seperate. I am most concerned with sorting out the DVD problem and would be keen to know from anyone who might have seen similar problems and especially from anyone with an idea of what I might try.
  5. berry
    berry
    Nov 9, 2003
    45
    London
    Deman77,
    How does the Q Sync from QED compare to the JS RGB to VGA converter?
    Is there a notable improvement in quality?
  6. deman77
    deman77
    Aug 20, 2003
    260
    16
    London
    I wouldn't know I never tried the JS but everyone around here says it's great.
    You will hardly see a notable improvement in quality if at all between QED and JSTech because they are both high quality. I have seen notable improvement when I switched from scart to sync extractor but between two quality active sync extractors you will be splitting hairs.
    QED was good for me because I needed exactly 3m of run and QED comes with 2m VGA and 1m Scart. So the QED at 150 turns out cheaper then JSTech at 120+cables 40-60Scart+50-120VGA. With JSTech you will need to get your own cables but then you can get any cables you want and you will want to spend about the money I indicated, otherwise you may as well stick to the scart connection as bad cables will kill all the good work. With QED the scart is wired in (with nice fat RGB QED scart cable) and the VGA cable is detachable (looks like it's shielded as well), still cheaper than JSTech even if you chuck the VGA cable and get your own.
  7. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Toshiba DVD's have had this problem reported before, with a plasma. I think it was a PW6. Try a search for toshiba dvd in the plasma forum, it was a couple of months ago. But it does sound like the panel is very sensitive to less than perfect signal, there may be no cure. It's a price you pay for LG quality. There is a saying, that there's nothing in the world that can't be made a little cheaper by being made a little worse. I'm very much afraid that this is what happens in Korea. Though Tosh shouldn't make excuses like that, they're supposed to be good!
  8. mpf2003
    mpf2003
    If the LG was the only screen to do this i may agree but i know there are threads about other makes that do similar. Also i read somewhere that LG manufacture screens for Sony so they cant be that bad.
  9. RossC
    RossC
    Feb 13, 2003
    144
    berry,
    I tried both a Qsync and a JS RGB > YUV and did notice a difference - the JS device produced a cleaner picture on my NEC plasma. The QED seemed to introduce a grainyness that wasn't present with the JS.
  10. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Who said sony LCD's were any good? No seriously, LG do not make stuff for sony, they are owned by philips, and even philips don't use LG to make their stuff. Sorry about the cheeky sony comment, they're just a little pricey
  11. deman77
    deman77
    Aug 20, 2003
    260
    16
    London
    RossC,
    It's an interesting comparison, but it's not exactly like to like.
    You need to compare Qsync to JSTech RGB-VGA converter.
    I remember there was a discussion a few month ago what's better JSTech-YUV or JSTech-VGA converter and some people preferred component because it was softer and more natural while others liked VGA because it was sharper (shraper means grainier because you see all the artefacts clearer). The colours also differ slightly between the two.
  12. berry
    berry
    Nov 9, 2003
    45
    London
    Deman77 / RossC,
    I've managed to get a loan of the QED and will see how it works out (hope to get the plasma this w/e). Don't have access to the JS RGB2VGA so cannot compare.
    Also, still haven't figured out my DVD/STB/VCR connections to the PWD6!! .. and should I invest in a Quintro+ (or the new Vivanco AV Control 5due out in a few weeks)?
    I continue to welcome your suggestions on any of the above.
    regards,
    berry
  13. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    I've tried them all, and JS works most reliably, and best PQ, though this is of course subjective. The quintro is another iffy device, said to be fixed, but I haven't tried the new version. Just bear in mind that you are all buying premium technology displays, it's pointless and self defeating to start penny pinching on adapters and cables, you get only what you pay for
  14. scgf
    scgf
    Nov 16, 2003
    444
    28
    Market Harborough, Leicestershire, UK
    +26
    I have recently installed a Hitachi 42PMA400 plasma screen. I bought a JS RGB2Component converter having been told this would be the only way to connect my RGB devices to the screen.
    I have been getting the dreaded dropout problem when watching DVDs - a black screen every five minutes or so, sometimes two or three in a row.
    Today I decided to make up a SCART -> 4 phono lead so that I could feed the screen with RGB & CVBS for sync. I had some decent phono cables so set about the task.
    To cut a long story short, I have now eliminated the dropouts. I have a redundant JS converter and TechLink component cable set, but in the process I have achieved a better picture. Initially I thought it was grainy, but after tweaking the sharpness etc. and comparing it with the picture through the JS it is actually showing a lot more detail - evident in faces particularly.
    Interestingly I have also eliminated lip-sync issues I was having with Sky.
    Is there a decent online source for made-up SCART->4 phono cables? Given my just average soldering skills and the abundant use of insulating tape to keep the SCART terminals from touching I am sure I could improve on that picture even more with a better quality lead.
  15. MR2Harvey
    MR2Harvey
    Sep 29, 2003
    460
    +6
  16. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    I used to get Lektropaks to make mine, but now make my own as it's so much cheaper. But their silver screen and pro stuff is pretty reasonable. They don't have a 'designer' name, but the bits they use all look OK to me, and joints properly done.
  17. scgf
    scgf
    Nov 16, 2003
    444
    28
    +26
    The cable I made up has a bog-standard SCART plug at one end, 3 x 2m lengths of Prowire Triple Internconnect (originally phono to phono cables - I chopped the phono plugs off one end to connect into the SCART plug) and 1 x 2m cheapo screened cable for the composite connection. I twisted the outer screen of the three Prowire cables together and connected that to the metal part of the SCART plug. (Obviously each individual connection is separately screened and connected to the appropriate SCART pins - the cable is double screened).
    The lead connects between the plasma screen & a Quintro+ switch box
    Am I realistically going to improve things by spending 50 quid on the Lektropacks ProLink equivalent? I am quite prepared to splash out if it is worth it.
  18. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Probably you will, without meaning to cast aspertions, sorry mate! The only drawback of the lektropacks is working out which one is which! Post again if you're lost, I've still got a labelled on here for reference.
  19. manc
    manc
    Apr 3, 2003
    150
    19
    I think i may knock one of these up just out of curiosity.
    Are you using the seperate component out plug or the one from the scart plug as the sync sigal. If its coming from the scart wich pin is it? 19 and 17 for ground ?
  20. scgf
    scgf
    Nov 16, 2003
    444
    28
    +26
    Yes, exactly that.
    5 - Blue ground
    7 - Blue
    9 - Green Ground
    11 - Green
    13 - Red Ground
    15 - Red
    17 - CVBS Ground
    19 - CVBS
  21. scgf
    scgf
    Nov 16, 2003
    444
    28
    +26
    MAW - decided to take your advice and buy a made-up cable. A company caled CPC (not heard of them before) sell a SCART to 4 phono lead, specifically for this purpose. They use Van Damme OFC cable. Unfortunately the lead is terminated with BNC plugs, so I had to order 4 phono plugs.
    The link to the lead is http://makeashorterlink.com/?P2A812F86
  22. deman77
    deman77
    Aug 20, 2003
    260
    16
    London
    scfg
    Please keep in mind that passive converter will be worse than the active extractor.
  23. MR2Harvey
    MR2Harvey
    Sep 29, 2003
    460
    +6
    I'm lost here, can you explain?
    Harvey
  24. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Nothing to explain, he's not absolutely correct. For a start, an active sync extractor like the JS RGB to VGA won't work with the Hitachi, and for another, it's not miraculously adding anything to the signal that wasn't there in the 1st place. The device is popular with panasonic owners, particularly 5 series, as it adds a scart connection to your screen without taking up the YUV connections, but on the PMA400 you have loads of YUV connections, it's not an issue in any case.
  25. manc
    manc
    Apr 3, 2003
    150
    19
    Ok, at the risk of sounding stupid :)
    I have made my lead but cannot get a picture apart from a composite picture using my sync carrying lead - when i attempt to use the rgb i get an out of frequency error.
    I am probably being incredibly dim but could you tell me exactly where you plugged the 3 rgb leads?
  26. MR2Harvey
    MR2Harvey
    Sep 29, 2003
    460
    +6
    (I have not got this screen yet will do soon) You use the component inputs for RGB and composite input for composite sync. Have you set the component inputs for RGB or is it still setup as YUV?
    Harvey
  27. manc
    manc
    Apr 3, 2003
    150
    19
    I cant see any options to configure the YUV as RGB :S
  28. MR2Harvey
    MR2Harvey
    Sep 29, 2003
    460
    +6
    AHHHHHH I can't believe it... I am now completely confused how do you connect up the 400E. On the Hitachi site it shows it being connected by RGB and sync on composite!
    Help!!!! :)
    Harvey
  29. manc
    manc
    Apr 3, 2003
    150
    19
    You got a link m8 might help me out ?
    *edit*
    Works great after re-wiring my connections - think it would be better with a quality cable. I think this is certianly the way forward with this display as an alternative to expencive converters :)
  30. MR2Harvey
    MR2Harvey
    Sep 29, 2003
    460
    +6
    http://www.hitachidigitalmedia.com/
    You will see the connection wizard at the bottom right hand corner.
    Harvey
