RGB to Component conversion on Sony HX900
Discussion in 'Blu-ray & DVD Players & Recorders' started by Timbo21, Mar 17, 2005.
  1. Timbo21
    Timbo21
    Dec 23, 2004
    4,632
    3
    London
    +315
    Does anyone know if the HX900 will output component when you have a scart
    input (L3). The reason is I want to use it to convert scart RGB to component,
    since projector I want to hook up to only has component & DVI ins.
    Thanks,
    Tim.
  2. Timbo21
    Timbo21
    Dec 23, 2004
    4,632
    3
    London
    +315
    Anybody out there? Rasczak you must know this one. :)
  3. apj30
    apj30
    Yes I'm sure it will. I have the RDR-GX700 and it successfully converts composite, S-Video and RGB input signals to component output.
    Note that the unit needs to be turned on for this to work.
    Cheers,
    Andy
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,710
    Warwick
    +2,586
    Yes it will - although, as with all DVD recorders that do this, the results vary depending upon your machine/tastes. Some people swear they see a dramatic improvement, others say the converted RGB picture is 'like composite'. I would say try it and see - if you not happy you could always buy a dedicated RGB to Component converter.
  5. Timbo21
    Timbo21
    Dec 23, 2004
    4,632
    3
    London
    +315
    Thanks Rasczak, I knew I could rely on you :)
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,710
    Warwick
    +2,586
    Many thanks for the vote of confidence!
