RGB to componant convertors
tee2
Hope i've posted this in the right section.
I have a Panasonic 42pdw6 with a componant board.
I also have a Denon 3803 with two componant ins and a componant out.
The problem is that my Sky box has RGB out. I am running it normal composite video at the moment and the picture is terrible!
I have found a RGB to componant convertor at Lektropacks for £75
Are these any good?
Will it improve my picture alot?
Is this the only option?
Cheer for any help.
T
CARLOS
Hi mate
I haven`t tried the Lektropacks converter as the recommended one that most people on here use is the JS Technology one.
You should get a big improvement over the composite signal you are currently using !
P.S Good choice of Plasma ;)
PP.S I have a JS converter for sale if your interested ? :)
tee2
Cheers mate
Yes I would be very interested in this converter.
How much do you want for it?
CARLOS
tee2 i would be looking for £100 for it ?
LMK if you`re interested.
JIT yes you would need a converter, The leads you show would only work if your digi box output component through the scart and the only one i know that does that is the Netgem unit ?
Edit Those leads still wouldn`t work as they are the wrong way round (component to scart) you would need scart to component !!
ridd
i have a brand new lektropacks rgbtcomponent converter for sale.
As i bought one too many.
JIT
Thanks, i think i'll just keep my box connected directly via RGB scart - cheaper than having to buy a converter.
Podcast: LG C1 OLED + JBL Synthesis SDR-35 First Thoughts, plus TV Show & Disc Reviews & more
