rgb to comp/vga
Discussion in 'Plasma TVs Forum' started by lab, Feb 12, 2003.
  1. lab
    lab
    I have a panny th50pd30 and I need to connect ntldigital via rgb scart.I have seen various rgb to component converters and rgb to vga converters but I can`t work out which will give the best pq.Can anyone advise please?
  2. bobthebuilder
    bobthebuilder
    RGB - Component, I believe gives the best quality.
  3. d_devani
    d_devani
    th50pd30 - is that a plasma or TV.
    RGB to Plasma VGA is the best for quality
    followed closely by the RGB to Component
    Check out http://www.rgbtosvideo.com
    Allot of people on this forum have bought stuff from the above site, including myself. The sight has allot of useful information, and they are very helpful.
  4. jont
    jont
    Apr 8, 2002
    4,251
    near Aylesbury
    +551
    If you are looking for a cheaper but best product-quality solution I have one of the JS RGB>VGA converters for sale over in the classifieds ...
    rgds
    Jon
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,763
    The Borders
    +3,088
    lab
    The JS Technology RGB2VGA converter is very slightly 'cleaner' than the RGB2YUV converter - though there's not much in it.
    If you use your NTL box quite a bit I'd possibly go with the RGB2YUV and at some point try out the Silicon Image iScan Ultra between the NTL box (and any other YUV, Composite and S-Video sources) and the Plasma display.
    The Ultra takes in YUV not RGB so if you want to get the best out of the NTL/Plasma combination (and would be willing to spend £850 or so on the Ultra) I'd go down that route.
    Best regards
    Joe
