RGB to Cat5e
Discussion in 'Cables & Switches' started by PaulDG, Jul 25, 2004.
  1. PaulDG
    PaulDG
    I have been trying to nut out a solution to the following and might need some help.
    I have a house with structured cabling routed through a hub out in the garage. What I want to do is connect my PC (in the office) to a Denon AVR-3803 Receiver (in the Home Theatre) so that I can play video and music files. I have a Cat 5e and RG6 Coax inputs on a wall plate behind the PC and the Denon. The hub has a video modulator.
    I figure that I need to convert RGB from the PC to Cat5e and then from Cat5e to component, but really don't have any idea on how to do this. :confused:
    Would appreciate any ideas please. :suicide:
  2. clockwork
    clockwork
    Oct 13, 2002
    42
    Edinburgh
