rgb + sync to Scart connector
Discussion in 'Cables & Switches' started by nathsea, Jan 12, 2004.
  1. nathsea
    nathsea
    Apr 26, 2003
    917
    +24
    Hi all,
    Here for a bit more advice.
    I need to run a video cable from my extron box which has RGBS BNC connectors to my scart connector on my 1031qm Projector. I have been thinking about running seperate 75ohm coax leads but am worried about fitting them in to a scart plug due to their size. I have also looked at the van damme red 4 core coax cable , which looks good but is quite expensive.
    I need to run about 10 metres so any suggestions welcome I am quite happy to pay for decent cable like the van damme if that would be best.
    Many Thanks
    Nathan
