RGB & SKy
Discussion in 'Sky Digital TV Forum' started by bob mushroom, Feb 1, 2003.
  1. bob mushroom
    bob mushroom
    Jan 26, 2003
    771
    +20
    Just been setting up my Sony TV KV32-FX66 properly.
    Have RGB connection into AV 1 from SKY+ with a QED lead.
    On my old telly (panny) if you switched Sky on it would automatically turn to AV1 channel (I thought this was because RGB signal was being recieved)
    Is this possible with the Sony tv or not, can I "educate it" - if not why did it do it for the Panny?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    Are you using the same scart lead as before
  3. bob mushroom
    bob mushroom
    Jan 26, 2003
    771
    +20
    ian J - No I have changed from orig one that came with sky to QED 2000 times better
  4. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,897
    71
    50 Rue St Georges, Paris.
    +29
    What happens if you use your previous lead ?
  5. Rookies
    Rookies
    Jan 4, 2003
    4,932
    103
    +349
    bob mushroom
    I have the same tv set as you and am suppose to be getting you a picture of my settings in which i have forgotten all about. i will get that done for you.
    Regarding AV1 and sky it should auto switch over as it does with mine well I aint got sky + but got sky digital.
    Now on the side note what do you think of your FX66 picture wise. Have you notice grains and pixels on some programs on your tv i suppose it depends how far your got your sharpness set.
    Maybe you could let us know your setting for picture too and we can compare each other settings. i will try and get mine sent later on for you
  6. mjn
    mjn
    May 24, 2001
    18,392
    Herts, England
    +5,477
    assign the RGB input to a channel number on the Sony TV, then use the channel number to select RGBinput.
  7. bob mushroom
    bob mushroom
    Jan 26, 2003
    771
    +20
    rookies - at the mo put on movie picture setting and then put contrast up to 3/4 - this was good picture for "SWORDFISH" and DVD's watched last night yet on Premiership both mine and my wife's eyes started to hurt due to the blocking (in the crowd) and refresh rate on the ball. I am hoping to get some "play time" during todays footie on sky and try to get a descent picture for watching sport without the blocks.
    I have to say that I am very happy with tv - mate came (he has phillips 9567) he has the famous dark lines on his whilst watching DVD's - when he saw my picture his jaw dropped and stated that maybe he should take his back.........then he heard the buzzing!!!!!!! So the choice is yours, buzzing or bars....you decide.
    RGB problem (on earlier thread) all sorted and superb picture through this medium on Sony - quite impressed with the Smart mode once I played with it - not too much picture loss though not as good as my old panny 28PK2
  8. Rookies
    Rookies
    Jan 4, 2003
    4,932
    103
    +349
    Hi Bob
    I think you be better turning the sharpness down for football.
  9. AndyChap
    AndyChap
    Oct 16, 2002
    13
    Bob
    I have the same problem with Sky+ not auto switching on a Sony KV36FS76. Previously had a 32" Sanyo and had no problems with Sky+ auto switching.
    I have tried several SCART leads.
    Any suggestions would be appreciated.
  10. AOD
    AOD
    Feb 7, 2001
    710
    London
    +4
    Check the settings on your SKY box.
    Go into the menus, setup, then I think its under Picture Settings. You're looking for an option called "SCART control" which should be set to "On" or "Yes". Can't remember which.
