rgb sighn
Discussion in 'General TV Discussions Forum' started by jelly, Oct 21, 2003.
  1. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    on my tv i cannot get a rgb signal at least thats what i think i have everything set to rgb but if i change input source (usually on a rgb you get a arrow going into a circle with 3 little dots) but on mine it doesnt all i get is a arrow going into a circle with an s in and a arrow going out is this a rgb signal
  2. bodyfodder
    bodyfodder
    If you have an RGB signal going into the tv (in an RGB scart socket) then the tv should auto switch to the correct AV channel.
    On my old sony that sign ment that the tv was being sent a svideo signal but i had to change the channels manually.
  3. manhar
    manhar
    Oct 19, 2003
    163
    uk
    I have an arrow going into the circle but no dots to be seen. Is this RGB signal?
    Sony IDTV with rgb enabled scarts x2.
  4. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    does anyone have a picture of a rgb sign at all
