RGB SCART with Audio Cables
quarry2006
I may be peeing in the wind here but it's always worth asking: is there anyway on god's green earth that I can get hold of one of these? GAME don't appear to do them anymore and a search on Ebay has proved fruitless. I know the Cube is all-but dead now (the lease of life given it by Resi 4 seemed short lived) so it's hard to get hold of any hardware for it but I've only just upgraded my system and now want an RGB picture to go with my 5.1 sound so I can enjoy the likes of Rogue Squadron to the max.
Fatbob1080
Or you can buy mine for a tenner :smashin: It doesnt have audio cables but it has the L & R jacks to plug the cables into... :p
quarry2006
Pantera, thanks for the link but they don't appear to have the RGB with the audio leads. Or is it the AV-S Video cable I should be looking at?
Fatbob, thanks for the offer but no. I'd have to then buy two separate audio cables wouldn't I? Had I been looking for one when they were widely available, I'd be paying a tenner for the whole deal. And it would be new, too.
quarry2006
Marvellous. Thanks for that - will order it straight away.
Fatbob1080
From what i gather from reading the description, that one only works as a composite cable on the gamecube, same as the one that comes with the machine. Of course i *may* be mistaken...
quarry2006
Or you *may* be trying to get me to buy your overpriced, used cable!
There's a SCART lead; why do you think it only works as a composite?
Fatbob1080
I am shocked and hurt that you would think such a thing! :p Its the line at the bottom of the description that makes me wonder as it says 'Only AV compatible on Gamecube'. Depends what it means by AV although it mentions theres a switch to change between rgb and av if its connected to a ps2 so im assuming theyre saying 'av' is not rgb...
I know that the s-video connector on the cable doesnt work with the gamecube as a customer review of the universal cable linked to at the top of the description says so. So it wouldnt surprise me if the rgb scart on this cable didnt work with the cube. But like i say, i might be completely wrong! :smashin:
The_Wierd
The_Wierd
TBH I meant thats type of cable he needs, rather than the multi-console cable, not necessarily that exact one. For 2 quid, I'm sure you get exactly what you paid for, but the official cables are quite hard to come by now.
I must say that the RGB output on the 'cube is the worst of the consoles I own. Even with the official cable the image is better than composite, but its not amazingly better, especially on a large plasma.
nikz06
If you've got component on your set you should get the GC Component cable! Very pricey for cable but it can project upto 480p on compatable games.
quarry2006
Not looking to spend much, so the component cable would be out of the question I'm afraid.
That one you provided a link for, The Weird, how do I connect that to my amp? Are audio cables easy to come by?
Racquel Darrian
quarry2006
Thanks muchly for that; I'll post an email to the seller now, see if it's what I'm after (gotta get some more life out of this dying console one way or the other; I'm barely into Wind Waker, XIII and the sublime Killer 7 and I'm on the third replay of Resi IV (that game's just too good) and it would be nice to finish them off with some decent sound).
The_Wierd
You would just use normal red and white phono cables, the same as you would use to connect a cd player or other audio source to the amp, these needn't be expensive, a couple of quid for the cheapest, or as much as you want to pay. As far as I can tell you will still need one of these cables even for the 'Ultimate Scart cable' (which does look pretty good BTW).
This sort of thing (okay so its red and black, but I'm sure you get the idea):
quarry2006
I do like the look of that ultimate SCART lead. It was on Ebay (or one like it) about a week agao. Not there now, though.
Right then, that's what I'll get, and a couple of audio leads too.
Oooh, mid-monthly indulgences, the missus won't be pleased!
Racquel Darrian
I've got one and it's rubbish. Trust me. Full of crosstalk.
The one on Ebay is gone as I bought it. :clap:
Stick to the Ultimate Scart lead and you won't go wrong.
Racquel Darrian
You don't need these leads for the Ultimate Scart lead as it has them attched to the scart end. The audio leads are about 6 feet long.
quarry2006
Hang on a minute, the ultimate SCART lead is crap but that's the one I need to get? I'll need to buy the separate audio leads if I get it but then again, no I won't?
Why are you clapping your hands (it's unseemly to be smug, by the way, Raquel) if you bought a lead you declare to be crap?
Am I missing something here?
You're both feeding me a mess of contradictions, or so it seems. I appreciate help, don't get me wrong, but a little consistency would be equally helpful.
Racquel Darrian
Yeah there is some confusion here.
The £2 one, mentioned in #10 is rubbish.
The Ultimate Scart lead is good.
The Utimate scart lead does not need audio leads as it has them attached.
Confusion over?
quarry2006
The one you posted a link to on Amazon that costs £7.98, Raquel doesn't have audio leads, it has jacks for them to connect to. Is this the crap one?
Anotherlimey, I didn't find one I'm afraid. I scoured the length and breadth of town on Saturday with my two year-old daughter in tow (she has the patience of a saint!) and the best I was offered was a composite cable from Gamezone (the lad was really helpful and everything but I alrerady have a composite cable).
Are you serious about sending me one for nowt? If so, I'm eternally grateful and I'll PM you my postal address.
Latest News
Hisense TVs get Disney+ on VIDAA smart OS
  • By Andy Bassett
  • Published
Astell&Kern launches entry level SR25 MKII portable music player
  • By Andy Bassett
  • Published
LG rumoured to release 97-inch OLED TV in 2022
  • By Andy Bassett
  • Published
What's new on Blu-ray (UK) for Halloween 2021
  • By Mark Costello
  • Published
AVForums Movies Podcast: 20th October 2021
  • By Phil Hinton
  • Published
