RGB SCART to Y/C (or S-Video)
Discussion in 'Cables & Switches' started by klode, Sep 28, 2004.
  1. klode
    klode
    Hi @ all! :clap:
    I'm searching about a circuit that can convert a RGB Scart signal to S-Video YC signal.
    The simple connecting between SCART pins and S-Video pins is not a good solution :thumbsdow ; however, using a capacitor of 470pF placed on parallel between the C signal and C-ground signal can resolve (partially) the problem of the color on the images.
    Anyway, I'm searching for a best solution; I'd found something here:
    RGB to S-Video Converter
    but the core CXA1645P RGB Encoder component is not available here in Italy. So, this solution is not realizable. :rtfm:
    Is there anybody who know a solution for this problem???
    I mean, if it exist, I'll place it in a DEDICATED WEBSITE!!! :devil:
    Best Regards
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,883
    The Borders
    +3,117
