RGB scart to VGA on AE100
Discussion in 'Projectors, Screens & Video Processors' started by GPMCDERM, Dec 23, 2002.
  1. GPMCDERM
    GPMCDERM
    Dec 12, 2002
    109
    I got the panny last week and have been having a great time with the component output from my Sony DVD but I wanted
    to try out the Gamecube and I normally have it running on my
    TV using RGB scrat which the panny don't have so I used the
    crappy free composite lead and its crap looking....is there any
    cables/adapters that can take the RGB scart output and
    connect it to the VGA input on the projector....looking at the
    difference between svideo and component with the DVD I won't
    bother getting a svideo cable for the cube.
    Any help would be great....cheers..
  2. Blofeld
    Blofeld
    Dec 7, 2002
    465
    Twickenham
    +6
    Best solution to get a proV, try www.av-sales.co.uk
    you can run all your inputs into it plus it will give you a prog scan output, facility and quality, what more could you ask.
    Cheapest option is to buy a component lead for the cube
