rgb scart to vga converter? any good?
Discussion in 'Plasma TVs' started by usman24, Sep 26, 2005.
  1. usman24
    usman24
    Aug 3, 2004
    1,774
    41
    Birmingham
    +23
    I am on the verge of purchasing phd8 panny. Inputs confusion. I am adding inputs hdmi and component board or vga from a freeview box to screen. Which one would be better for freeview and do I need to purchase a rgb scart to vga converter such as the js tech unit?
    With vga, will the screen be able to turn it into a progressive image like component inputs?
    Anyone?
  2. djwoody
    djwoody
    Sep 7, 2005
    113
    Hi, I have just bought a PHD8 and had the same problem. I bought a scart RGD to VGA cable from Maplins and it works a treat. Great solution for only £60
  3. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    everything you throw at a progressive plasma (most, inc pannys) will be turned into progressive, its the only way they can work.
  4. usman24
    usman24
    Aug 3, 2004
    1,774
    41
    Birmingham
    +23
    the maplin website seems to show 3 connection 1 x scart, 1x vga connector and a third connection, what is that for?
  5. Mep
    Mep
    Dec 25, 2004
    9,497
    +460
    its probably the power cable. The JS is a lot better
  6. usman24
    usman24
    Aug 3, 2004
    1,774
    41
    Birmingham
    +23
    HI MEP, DO i NEED MALE TO MALE VGA LEAD TO PANASONIC INPUT? By the way why is js tech one better?
  7. Mep
    Mep
    Dec 25, 2004
    9,497
    +460
    yes it's male to male. The JS uses the best components but in terms of PQ results it gives a much better picture, better, more realistic colours and much sharper images.
  8. w3dal
    w3dal
    Aug 4, 2002
    4,796
    Chelmsford, Essex
    +507
    Ill stick in my two pence and give a thumbs up for the JS Box - They Rock!
    Dal
  9. dickst3
    dickst3
    Sep 15, 2005
    504
    +4
    JS box :thumbsup:
  10. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    JS boxes are fabulous quality, nothing else comes close.
    StooMonster
