(RGB?) Scart to S-Video
Discussion in 'Cables & Switches' started by Deez Nutz, Jul 31, 2004.
  1. Deez Nutz
    Deez Nutz
    New to the game so please excuse my ignorance and apologises if this is in the wrong forum.
    I have just purchased a Cambridge Audio DVD recorder (+R & +RW. )Unfortunetly it has no scart input but does have a s-video which I was informed by the salesman is better. From my reading on the net I've since come to doubt this however the proof is in the pudding. Anyway I have connected the recorder to my Sky digibox using a scart lead that terminates in a S-Video connection with audio phonos. The picture is subsequently black & white, my question is, is this because the scart socket on the back of the digibox is not RGB or because I need a RGB to S-Video converter. Needless to say I have selected RGB output on the digibox.
    I was led to believe that a RGB scart socket puts out a S-video signals inaddition to RGB and audio.
    My Sky box is an Amstrad DX400.
    Thanks in advance.
    :lease:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Done by an RS salesman unfortunatle mate, if you paid more than £270 take it back and buy a panny DMR-E55 or if less buy a JS technology RGB>S-video converter, top bit of kit (needs connecting to TV scart on box, but has pass through to TV)
    PS S-video is not better than RGB!
  3. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    A normal Sky box doesn't output s-video although a Sky plus box does. If your DVD Recorder doesn't accept an RGB input you are limited to composite only which is the poorest quality.
    I agree with hornydragon's suggestion that you exchange the dvd recorder for one that is fit for the purpose you bought it for.
  4. sr_edinburgh
    sr_edinburgh
    I've had the same problems, there are a couple of boxes out there (Grundig GDS3000 being one) which offer an s-video port. You can pick one of these up at reasnoable cost on eBay.
    The other way to get around the black and white picture problem is to use a scart adapter, but instead of plugging a s-video s-video cable in plug in a s-video to composite cable into the composite output on the scart and in my experience this also works well. Although the GDS3000 is simpler ;-)
    Check out www.svideo.com for a svideo - scart cable.
