MAD ANDY
Established Member
Hi all
I currently have a Panasonic SC-HT70 DVD player with scart, S-Video and Composite video out. I also have a Sanyo projector with S-Video and component in.
I was originally advised to buy a composite cable to connect to the pj which I did - then found out composite was the worst possible video cable and to upgrade! As I dont have component out on the DVD player, I have been looking for a s-video to s-video cable... then I found this:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=11073&item=5763245029
I have just bought some Thomson RGB scarts for connection between the DVD-TV and Sky-TV, and the seller of these mentioned he didnt believe the RGB scart to component cable would work properly, just after some advice as to whether this is correct or not, just on the basis that if the cable has been made, what use is it if it dont work?
If the cable above is no use, the choice after that is one of these two:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=67859&item=6765798018
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=32837&item=5763222984
Confused on the second one though as the seller mentions 'sound' - thought s-video was for video only?
TIA
Andy
TIA
Andy
-- As an eBay Associate, AVForums earns from qualifying purchases --
