RGB SCART Required : Help on selection
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dolbyz, Jul 9, 2005.
  1. Dolbyz
    Dolbyz
    Looking at buying a DVD recorder soon, as everyone I look at lacks one of the 3 below features! I'm looking for a model that has at LEAST 2 of the 3 features listed :
    1) Build-in Hard drive (80GB+)
    2) DV input
    3) 2x RGB SCART inputs, and 1x RGB SCART output
    Any suggestions?
  2. bradavon78
    bradavon78
    May 31, 2004
    3,202
    South West, England
    +133
    Just some friendly advice you may want to change the title I was about to give you some links to decent scart cables.
  3. JayCee
    JayCee
    Jan 20, 2004
    22,311
    Lanarkshire
    +2,324
    Toshiba RD-XS34 fulfils 1 and 2.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,708
    Warwick
    +2,584
    There aren't any DVD recorders that meet this requirement - at most they all only have 1 RGB input scart. You can get around this by using a 2 into 1 scart connector or using RGB loopthrough (which is found in most dual scart devices).
  5. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    I'm pretty sure you won't find (3) anywhere.
    You will find front s-video, composite video and L/R audio-in on the front of most machines, so you could get a scart > s-video+audio cables http://www.maplin.co.uk/Search.aspx?criteria=scart s-vhs&doy=10m7&source=15 S-video is almost indistinguishable from RGB. The cabling won't be as tidy, but you'll have the extra input.
    For (1) and (2) look at the Pioneer 530
  6. Dolbyz
    Dolbyz
    Thanks for the advice.
    Does this mean you won't get a DVD recorder that can record 2 seperate sources in any format then? I would like to connect a second DVD player AND a satellite decorder through the recorder - like an AV1 and AV2 connection - and I don't mind any connection (from the posts I see there isn't 2x RGB SCART connections - so even S-VHS or composite will do). I don't want to use the connecters on the front of the machine and have cables dangling everywhere.
    Regarding the loop through that Rasczak mentioned ... what, and how exactly, would one do this? I'm not techincally savvy, but both my satellite decoder and DVD/SACD player have dual SCARTS and handle RGB.
    For the 2 in 1 SCART connecter - I guess I get up and flip the switch manually all the time?
  7. nwgarratt
    nwgarratt
    May 5, 2002
    27,184
    +3,037
    You are not going to get a recorder with three scarts. You have to daisy chain them via scart. Something like DVD player through Digibox to Recorder to TV. You will probably need the digibox off to see the DVD player output on the TV. I would use a scart switchbox instead.
    If there is more than one RGB scart on the TV. You can put the DVD player on the second TV scart.
  8. Dolbyz
    Dolbyz
    Alright ... I'm going to daisychain my system.
    DVD player > Satellite decoder > DVD Recorder > TV set ... and all will be connected via RGB SCART. Problem now is which DVD recorder has RGB SCART? It's ruled out the earlier ones I looked at, and now I'm looking at whole lot! Which ones have these?
    Not sure where you are, but try not go above a Panasoinc EH50 level!
