RGB Scart recommendations for sky+ to jstech rgb2yuv?
Discussion in 'Cables & Switches' started by Ciqala, Apr 29, 2005.
  1. Ciqala
    Ciqala
    basically i'm looking to run my sky+ on my projector using component.
    the cable run is as follows...
    pace v2 sky+ box
    (??rgb scart??)
    JS Tech Rgb2Yuv convertor
    (mark grant component cable)
    denon av1905 amp
    optoma h30a pj
    can someone please recommend a 1m rgb cable that would fit well into this setup.
    looking at budget of £50 tops and that can be either for a new cable or perhaps a recommendation for a second hand cable i can try to source that would go for somewhere around that price.
    i know its a bit of an open question but i dont know my ixos from my van den hull or whatever so i'm wary of buying a dud lead that might not be as good as other leads in its price range because i know price does not always dictate quality.
    thanks in advance guys/gals :D
  2. AFC
    AFC
    Sep 9, 2004
    75
    I'm looking for something similar too.
    When connecting the Sky+ to the JS Tech box is it better to have an RGB only scart (with the other pins removed) or a full scart???
  3. Ciqala
    Ciqala
    bumppage :D
    even if people dont want to commit themselves to saying brand x is the best i'd appreciate if i was even just pointed in the right direction :)
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,243
    The Borders
    +2,940
    Hello Both
    We normally supply the Supra AV6 RGB Only SCART cables along with the JS Technology converters and that works a treat - though its over your indicated budget.
    Best regards
    Joe
  5. Ciqala
    Ciqala
    Hi Joe,
    thanks for your reply, you have pm.
