RGB Scart Question
Discussion in 'General TV Discussions Forum' started by Paul Spiteri, Apr 20, 2002.
  1. Paul Spiteri
    Paul Spiteri
    This has bugged me for a while now...
    I've got a toshiba 28W8DB tv and only EXT1 supports RGB, essentially making ext2 & 3 useless in my opinion.
    If I bought an xbox (and the extra rgb compatible cable! - bandits!) what on earth would I do. My tv decoder is in RGB1 !
    I currently have a dreamcast in my s-video / EXT3 connector and the quality of that is decent, although not quite as good as RGB scart in my opinion (i've tried both on it).
    I don't know if s-video cables are available for the xbox but really its not the perfect solution (Although certainly acceptable).
    Comments?
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,055
    You could get a Scart switching box....allowing multiple RGB sources to go to one RGB feed on your TV.
    s-VIDEO is available for XBOX. I'd guess RGB should be better....
    Gordon
  3. Paul Spiteri
    Paul Spiteri
    These switch boxes...do they cause any loss in quality?
    Why make tv's with 2 non-rgb scarts. it seems a lot suffer from the same condition
  4. dsb
    dsb
    because it costs less money?
    i agree though -when i bought my last set i made sure it had at least 2 of the scarts RGB compatible.
  5. Paul Spiteri
    Paul Spiteri
    and what set is this? what make should i be looking out for.
    i'm going to be replacing my tv sometime as its boned...but fixed itself.
    its very red when i turn it on for 20 mins and on a black screen theres is some green tint on the right side of the screen.
    crappy toshiba set...its 1.5 years since I had the tube replaced (364 days after purchase).
  6. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,909
    71
    50 Rue St Georges, Paris.
    +32
    Paul Spiteri,
    Philips, Panasonic, some models two RGB scarts.
    Toshiba, Loewe, some models two RGB scarts / and or component.
    Sony new FX66 and LS60 28"/32", oh, and the new Grand Wega.
    JVC X10 and P10 .
  7. Paul Spiteri
    Paul Spiteri
    Thank you.
    I've been considering the philips 28PW9617C. I looked in the manual and it has 2 RGB's so thats great.
    Just need some more £££ first!
