RGB Scart Problem - Please Help
Discussion in 'General TV Discussions Forum' started by Hummer, Apr 12, 2002.
  1. Hummer
    Hummer
    Apr 8, 2002
    3
    Surrey
    I've just bought a JVC AV-32WFT1 and Pioneer 444, both excellent apart from I can't get a picture when connecting them with a QED SQART AV41 (RGB) lead. I have set the output on the DVD to be RGB and it is definitely connect to the RGB socket on the TV (Ext1). There doesn't seem to be any way of setting Ext1 to RGB
    If I switch off the blueback function on the TV I can see the pioneer logo when I switch on the DVD but it very distorted (rolling diagonally across the screen).
    All is fine when using a regular (cheapo) scart in both ext1 and ext2
    Is there something in the service menu I need to adjust.
    Any help much appreciated.
    Tim
  2. swanny78
    swanny78
    Apr 19, 2005
    1,040
    48
    Matlock
    +66
    This is a directional Scart cable so the right end need to be in he TV. There should be an arrow which should point in he direction of the TV on the cable...hope this helps.
