RGB Scart - Plain scart?
Discussion in 'TVs' started by Mick da Miller, Feb 13, 2003.
  1. Mick da Miller
    Mick da Miller
    What is the difference between an entry level QED scart cable and an RGB one like this:
    http://www.empiredirect.co.uk/productdetailsnew.asp?modelcode=QED-AV4110
    Why is it 'no audio transmission'. Basically can I still get RGB through a decent quality scart without it having to be 'specialised' like this?
    Apologies to Groundy (who's been a great help) for re-iterating myself!
    Thanks!
  2. MattDX
    MattDX
    if you are linking your player to an amp (optical out etc) then removing the sound signal from the scart cable means less chance of signal interference as just the video is using the cable.
  3. Mick da Miller
    Mick da Miller
    Cheers mate - no I'm not linking it to an amp at the moment. So will a good quality QED scart allow me RGB output then?
  4. nathan_silly
    nathan_silly
    That ad is contradition- it says FULLY WIRED SCART and then UNUSED CONNECTORS REMOVED.
    Fully wired SCART is with audio and video.
    Which one is correct?
  5. Lesmond
    Lesmond
    Jan 29, 2003
    135
    +3
    Just go by what the QED site says:
  6. tom-m
    tom-m
    Feb 6, 2002
    153
    16
    Yes a good quality QED scart lead will give you an RGB picture, like MattDX says, the specialist RGB lead has had the sound wires removed to reduce any interference.
    The other QED leads are 'fully wired' so don't worry, as any of the QED scart leads will give you RGB...so will ixos which are slightly cheaper. ;)
  7. neilybealy
    neilybealy
    Jul 9, 2001
    1,539
    48
    Kent
    +55
    you've just answered a question i was going to ask
    thanks very much
    i've got to get a new scart but wanted it to do rgb and sound
  8. Mick da Miller
    Mick da Miller
    Cheers lads - now to decide on QED or Ixos:rolleyes:
  9. MattDX
    MattDX
    Don't rule out monster cable - they rock. Also the thor cable has had A+ reviews and is very reasonably priced.
  10. Mick da Miller
    Mick da Miller
    Do I need a better coaxial cable for my sky box as well?
  11. MattDX
    MattDX
    I don't think so. Just get some nice scarts.
  12. Bam
    Bam
    Where can you buy these Monster scarts?
    They don't seem to be very popular with uk online retailers- hence I haven't seen one on sale yet:confused:
  13. shaunashott
    shaunashott
    i just brought a 3m 24k cable from maplin (select electronics)?? anyone got these cables... they any good
  14. MattDX
    MattDX
    Strangely enough the best selection of monster cables I've seen is in Currys. They seem to be pushing the monsters big time.
  15. clearys
    clearys
    Dec 16, 2002
    125
    Sheffield
    +12
    I buy all my cables through Ebay.
    Got a 1M QED RGB for £27 and a Monster2 S-video to Scart for £10.
    Typical price for QED Fully wired is around £32 so quite a good saving there
  16. jim.rae
    jim.rae
    OK - so someone is now making money selling SCARTS with no audio signals...
    But has anybody on the planet actually seen audio signals degrading the picture quality?
    Bearing in mind that the whole purpose of SCARTs is to give a one cable solution to connections and they were carefully designed that way to include audio.
    The Emperor's new clothes come to mind!
  17. tom-m
    tom-m
    Feb 6, 2002
    153
    16
    I've always believed that if your dvd player is in the sub £200 bracket, then a scart costing £15 is not going to give you any less of a detailed noise free picture than one costing twice/three times as much.
    I have a Lektropacks home cinema scart, (HCSL14) found here http://www.lektropacks.co.uk/dept.asp?dept_id=203 and an Ixos 126 scart lead, and damned if I can see any difference in pic quality. Both give excellent RGB pictures. :p :D
  18. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    Glad to hear you got sorted - I forgot to reply to your other thread :blush:.
    Some good recommendations here but if you want my recommendations they are:
    1. QED Fully Wired Sqart (AV21) from Sky to Loewe AV2
    2. QED RCA Component to Scart (AV29) from DVD player to Loewe AV3. Set Loewe AV3 to YUV, sync on Y.
    Is it worth spending £50 on the AV29 for a £200 DVD Player? Probably not but you are buying a high-end TV and you won't have the £200 DVD Player forever. You will likely move to a higher-end DVD player in the forseeable future.
    OR
    2. QED Fully Wired Sqart (AV21) from DVD player to Loewe AV3. Set Loewe AV3 to RGB.
    As mentioned, there really isn't much difference, if any between RGB and Component on the Loewe.
    I recommend HiFi Cables for all of the above. Buy 1m versions if that is all you need.
    3. Cheapo standard Scart Cable from VCR to AV1 on the Vitros. Buy a gold-plated oxy-free one if it makes you feel better. Don't sepnd any more than £10 on this.
    4. Same as 3. for Digibox to VCR.
    Hope this helps :).
  19. Mick da Miller
    Mick da Miller
    Thanks again mate!
