RGB Scart output from PC
Discussion in 'Desktop & Laptop Computers Forum' started by PatrickB, Nov 21, 2003.
  1. PatrickB
    PatrickB
    I am disappointed with the quality of DVDs played back on TV from my Dell laptop (1.8GHz, Mobile Radeon 7500 graphics), using its S-VHS output. My 32 ins TV has a RGB scart input so I wondered if using that would be better than the s-VHS. I have a docking station that will take PCI cards, so I could use the Sigma X-card, which has RGB output. How does the X-card video quality compare to a stand alone DVD player? Presumably its much better than an external VGA to RGB scan converter, like the Grandtec GXP2000.
    Patrick
  2. Kramer
    Kramer
    I don't think PC DVD playback ever looks good on a "regular" TV, irrespective of connection etc..
    The X-card's RGB output is probably the best option available but given the low cost of standalone DVD players now, I'd say that is the best option.
    :smoke:
  3. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,742
    71
    Land of the Living, Essex
    +37
  4. Ivan8192
    Ivan8192
    May 2, 2003
    24
    Derby, UK
    Patrick,
    If your Radeon chipset supports interlaced + composite sync output from the VGA port (set up via Powerstrip), you can make a lead to directly connect the VGA port to your SCART socket:
    http://www.idiots.org.uk/vga_rgb_scart/index.html
    Regards.
    Ivan.
