hi people well yesterday i bought an L.G. RE44SZ21RD for £849 a pretty good price i reckon anyway in the manual it says that scart1 is the only scart of 3 that is RGB, whats the difference between a RGBscart and a normal scart? they all seem to work the same from the little testing ive done so far
RGB is the better connection. Make sure your hardware you are connecting supports it and use the right scart connection. By this I mean most dvd players might have 2 scarts but only one of them will be RGB.
avinitski where did you manage to pick it up for that price, it is one option I am considering and comet @ £999 is the best I could locate.
it was at my local EMPIREDIRECT clearance store in manchester, it was an exdisplay model, comes with 12 months parts and labour still
