RGB Scart Leads
Discussion in 'Blu-ray & DVD Players & Recorders' started by HatterNick, Mar 8, 2002.
  1. HatterNick
    HatterNick
    Mar 8, 2002
    80
    Northampton
    +5
    Is it worth me paying £35 for a Scart to Scart cable? Would a £9 cable do just as good a job? Will I notice much difference in picture quality on my soon to be delivered Toshiba 210 if I splash out on an expensive cable?
  2. Zone
    Zone
    Jun 24, 2001
    6,754
    Barnsley
    +2,459
    Give the good people on this forum some help, what will you be watching it on? A 14" portable or something a little bigger?
    BTW...Welcome ;)
    Si
  3. bob007
    bob007
    If your TV is a Toshiba check first to see if you can connect via component, this is regarded better than RGB. If you can't connect via component, then a good quality scart like the QED AV21 will be more than up to the job.
    Yes a difference in picture quality can be noticed between a cheap and cheerful scart and one of much better quality.
    Cheap scarts can be very poorly sheilded causing allsorts of picture interference.
  4. HatterNick
    HatterNick
    Mar 8, 2002
    80
    Northampton
    +5
    Sorry...I have a Sanyo 28" Widescreen TV. Not the greatest TV int the world, but the picture quality is pretty good for the price.
  5. Zone
    Zone
    Jun 24, 2001
    6,754
    Barnsley
    +2,459
    Bobs answered your question, why compromise? Up your budget a little and get something decent, as I have a JVC set seemed to make sense (at the time) to go with JVC scart VX-J126 with gold plated connectors and the picture from my 210 is excellent, all the best with your choice :)
    Si
  6. HatterNick
    HatterNick
    Mar 8, 2002
    80
    Northampton
    +5
    Thanks to both of you, I will invest in something decent. I am more concerned with getting the best possible picture as i don't have proper surround sound. Saw those JVC cables in Dixons, maybe I will go for them:)
  7. andypandy
    andypandy
    Feb 6, 2002
    594
    Surrey, UK
    +10
    yeh, and that's what I did (and said in previous posts) , but someone posted a reply and told me he thought that they were just as bad as the cheap ones !!!!
    There sems to be many praises for the QED range of scarts, may be best to get of those.
  8. damtom1
    damtom1
    QED 4110..the best value at www.empiredirect.co.uk
    38 pounds delivered,
    this really made all the difference to me,it only carries picture,there is another one though!
  9. DavidT
    DavidT
    Oct 30, 2001
    2,489
    +257
    I've got a couple of SCARTS that I bought in B&Q. They are made by Maxview and have the following spec.
    Fully wired
    Wires individually insulated
    Cable insulated
    Gold connectors and pins
    0.8m long
    £3.98 each
    Now thats what I call a cheap SCART but before you all laugh I have to say that my DVD and NTL Digital picture is excellent.
    David
  10. HatterNick
    HatterNick
    Mar 8, 2002
    80
    Northampton
    +5
    Thanks for that David, I will certainly check those out! My main concern is that the picture on my new Tosh SD 210E will be better than that of my Playstation 2 ( RGB enabled through RegionX)! Thanks to everyone who replied.
  11. paiger
    paiger
  12. Mr A
    Mr A
    Hello,
    I recently upgraded from a cheap scart to a £20.00 IXOS SCART the 162 model methinks. £20.00 is still cheap for a SCART but the picture quality improved, particularly flesh tones and background clarity.
    definitely a worthy upgrade. I have a tosh 28" widescreen and use RGB connection.
