RGB Scart for PS2
Discussion in 'Playstation Forums' started by rivolinho, Dec 5, 2003.
  1. rivolinho
    rivolinho
    Nov 17, 2003
    13
    I recently got an RGB scart lead for Ps2 from ebay.
    Well i believed it to be RGB, but i dont think it is. My TV prints the letters RGB onscreen when such a device is plugged into it, i.e. Sky Digibox, however it does not do so when my ps2 is in use through this lead.
    Also DVD's dont appear green on screen, which they should if this was an RGB cable. The cable does not have the necessary switch to go between dvd and tv mode.
    Can anyone help?
    Have i been had?
  2. watchmaker
    watchmaker
    Aug 22, 2003
    168
    +15
    Check that the scart socket you're using on the TV is RGB.
    Most TVs only have 1 RGB scart socket.
  3. wod
    wod
    Sep 7, 2003
    196
    +3
    it doesn't sound like a proper rgb cable , buy a decent one like the blaze ultimate scart lead or the ixos ps2 one
  4. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    The Blaze Ultimate Scart is a good one. It's about a tenner. I think Special Reserve sell them.
  5. mugsy
    mugsy
    Nov 1, 2002
    687
    Kent
    +20
    Check the scart plug on the cable and look for a small switch with a 'game'or 'dvd' setting. If it has one, make sure it's set to game.
  6. fuzzybee
    fuzzybee
    Apr 27, 2002
    1,498
    Chesterfield town of the crooked (Spire)
    +72
    The easiest way to find if something is outputing RGB to your tv is the autoswitch method. 99% of tv's/cables will autoswitch to the RGB AV channel when said device is switched on. Like other members have suggested look for a switch on the console connection end of the cable and make sure the cable is inserted into a RGB enabled socket.
    Add another vote for the blaze ultimate scart cable, it produces a superb picture on my 42" plasma :smashin:
  7. wod
    wod
    Sep 7, 2003
    196
    +3
    thought you be using component on the plasma
  8. outtathaway
    outtathaway
    Dec 2, 2003
    40
    2
    11
    huddersfield
    Have you set the PS2 to output RGB otherwise it'll be a PAL signal.
  9. rivolinho
    rivolinho
    Nov 17, 2003
    13
    Thanks for all the suggestions lads, found out the prob in the end.
    For some strange reason, when i use the skybox in the rgb socket, it accepts it on the av1 channel as "AV1 RGB" but it wouldnt autoswitch like this with the ps2.
    The tv is new so i hadnt explored everything on it. There turned out to be another AV channel called RGB would you believe!
    Job done.
  10. fuzzybee
    fuzzybee
    Apr 27, 2002
    1,498
    +72
    Thats a fair comment, sadly finances won't allow the purchase of a component cable at the moment, so RGB scart will have to do for now. I've been looking into a VGA adaptor but i don't think that many games actually support it, can anyone comment regarding this ??????
  11. wod
    wod
    Sep 7, 2003
    196
    +3
    i thought it was only the dreamcast that can output vga ?
