RGB, S-Video and RCA Component output to BNC Component input? Any thoughts?
Discussion in 'Plasma TVs' started by apj30, Mar 8, 2005.
  1. apj30
    apj30
    Hi guys,
    Is there a single solution to connect the following devices to component input please:
    - Sky+ with RGB output
    - DVD Recorder with RGB and Component Output
    - JVC SVHS Recorder with S-Video Output
    I'm managing it at the moment using Scart loop-through for the Sky+ via the DVD Recorder and a RGB - YUV converter. And not using the SVHS at all.
    Thanks in advance!
    Andy
  2. gstadt
    gstadt
    Sep 22, 2004
    270
    Cardiff
    +10
    What DVD recorder have you got? If its one of the Panasonic's it should have a S-video input.
    G
  3. apj30
    apj30
    Hi! Thanks for replying.
    It's the Sony RDR-GX700 and does come with S-Video input.
    But... how can I output that so I can see what's playing? I still need to convert the S-Video signal into YUV right..?
    Andy
  4. Mep
    Mep
    Dec 25, 2004
    9,542
    +468
    your dvdr should do it...i have sky going into my dvdr via svideo and then comoponent to the pw7..no worries
  5. gstadt
    gstadt
    Sep 22, 2004
    270
    Cardiff
    +10
    If it has got a s-video input, the Sony recorder should upconvert the incoming s-video signal to component, all you need to do is alter the input label on the recorder eg. feed Sky+ into what might be AV2 [you'll need to check as I've got a Panasonic E55] which will be your main input for recording purposes. You should have secondary input(s), possibly AV3 which is the s-video and composite audio, which is what the SVHS will plug into. AV1 will be your main component output into the PW7. You shouldn't need the RGB-YUV converter as the recorder will convert all inputs to component
    G
  6. apj30
    apj30
    Has anyone been able to convert RGB & S-Video signals to Component via a Sony DVDR?
    Specifically, the GX700 (or the GX300 which is pretty similar)?
    This would be the answer to my prayers :)
    Thanks for the info guys,
    Andy
  7. apj30
    apj30
    SORTED - yes it works, the RDR-GX700 will convert RGB input from Sky+ and output via component straight into the screen.
    However, the DVDR does need to be turned on for this to take place. Is that the same case for other recorders? Or can other recorders do the RGB - YUV conversion even in standby mode?
    Thanks,
    Andy
  8. gstadt
    gstadt
    Sep 22, 2004
    270
    Cardiff
    +10
    It's the same for all recorders because as there is a conversion taking place therefore it has to be on to power this. Not a big deal really though to have it on.
    G
  9. apj30
    apj30
    Agreed, it's no overhead at all.
    S-Video works perfectly too going from the SVHS recorder into the DVDR and then out via Component.
    Thanks for all your help.
