RGB question
Discussion in 'Satellite TV, Sky TV & FreeSat' started by manhar, Oct 23, 2003.
  1. manhar
    manhar
    Oct 19, 2003
    163
    uk
    Whys is RGB recording darker than non-RGB recording?
  2. gyre
    gyre
    Sep 9, 2003
    77
    9
    Bristol, UK
    Do you have your RBG cable split?
    -- gyre --
  3. manhar
    manhar
    Oct 19, 2003
    163
    uk
    No.
    Sky RGB out > DVD Recorder RGB in > DVD recorder RGB out >
    TV RGB in (AV1).
  4. nwgarratt
    nwgarratt
    May 5, 2002
    27,047
    +2,981
    Its darker, because with composite signals, you select a desired brightness, contrast, colour etc. You must have your composite settings higher/brighter than RGB.
    With a RGB signal, you can only adjust brightness.
  5. manhar
    manhar
    Oct 19, 2003
    163
    uk
    nwgarrat, I dont understand. I am receieving RGB signals on my Sony IDTV via RGB scart socket, but I am also able to change the settings for color, contrast and brightness via the Picture Menu Settings. Yet u say Brightness cant be adjusted with RGB?
  6. nwgarratt
    nwgarratt
    May 5, 2002
    27,047
    +2,981
    Brightness and contrast (got that bit wrong) can be adjusted.
    I have a Sony IDTV (28DX20). When watching digital TV, and press for he menu, colour, sharpness and hue cannot be adjusted.
    I also have a freeview box on RGB and when viewing it on the RGB input (same as DVD's), the same settings cannot be adjusted.
    RGB has always been darker than composite on my TV.
    Maybe your TV is different.
