RGB question
Discussion in 'Projectors, Screens & Video Processors' started by phcjpp, Mar 8, 2002.
  1. phcjpp
    phcjpp
    Jan 29, 2002
    71
    London
    I have a pioneer dvd with rgb scart out and a sony lcd projector with rgb inputs (5 of) - is there a cable that coverts between scart rgb and separate 'coax' rgb ?
    Chris
  2. DaveP
    DaveP
    It sounds to me that your projector connections are designed for a PC to connect its VGA connector to. These are not compatible with the DVD RGB!
    DaveP
  3. phcjpp
    phcjpp
    Jan 29, 2002
    71
    London
    the projector is a HT10 if that help
  4. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,625
    United Kingdom
    +2,227
    I´ve moved this here as you´ll get more chance of answer (being Projector related)
  5. Dangerous
    Dangerous
    I have a 10ht . You need a scart to 3 phono with sync on green(this is important). Try keene electronics
    Dave
  6. phcjpp
    phcjpp
    Jan 29, 2002
    71
    London
    Dave,
    I had a look at the site - a found various cables that might fit your description but nothing mentioned the sync on green as far as I can see.
    Chris
  7. phcjpp
    phcjpp
    Jan 29, 2002
    71
    London
    bump sorry.
  8. Dangerous
    Dangerous
    Look for "leads to go" then in the window look for "Scart to three phono plugs (RGB with sync on green). You will see this description: Cable type: 3 x URM70 digital coaxial.
    Connector Type: Gold Scart plug + gold bullet type phono plugs
    Typical usage: Scart - RGB sync on green. For DVD to TV - projector etc (no external sync connection). This a Scart plug that has the synchronisation signal taken from pin 19(sync) to pin 11(Green). I originally bought a Scart to 3 phono with a separate composite sync phono, which did not work. After some research I found that connecting pin 19 to pin 11 with a 50-ohm resistor in between that my 10 ht would work of my NTL digital box. It should therefore work off your DVD player.
    Dave
  9. phcjpp
    phcjpp
    Jan 29, 2002
    71
    London
    thanks very much - have ordered the part now. Thanks again.
    Chris
