RGB Question
grs
Hello just had a samsung le32r41b delivered, and when I put my xbox through the RGB scart, I can go to the colour options and make the t.v. go black and white, I thought you could not change the colour through rgb, also the picture is slightly blurry, is there certain setups on the options that would help the picture.Thanks
pjskel
SCART carries 3 signals - RGB (the best), S-Video (next best), and Composite. All that's happend is you've changed the setting to S-Video, which didn't tally with the output of the Xbox, hence the B&W display.
