RGB Question
Discussion in 'AV Receivers & Amplifiers' started by NapoleonGuitarSolo, Jul 14, 2001.
  1. NapoleonGuitarSolo
    NapoleonGuitarSolo
    Sep 22, 2000
    138
    Shropshire, England
    +9
    I, like many others, have the problem of only one RGB compatible scart on my TV. I had been considering a switch box but was wondering about the component inputs on a/v amps such as the Denons & Yamaha's.
    I know that component and RGB video signals are not the same and not compatible but if these inputs on the amps are transparent then surely you can just pass the red, green and blue signals through the component loops?
    Is this possible?
    NGS
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    The component video section of most amps will just pass through the video signal without affecting it in anyway. This allows you to switch more or less any analogue video thorugh it.
    For RGB you will need to utilise the composite video section of the amp also to use as a sync for the RGB signal. And on the monitor/TV end you will need an RGBS (phono) to SCART lead.
    Hope this helps!
