rgb problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by adox, Feb 10, 2003.
  1. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    i have my pioneer dv350 dvd player connected up to my panny 32" 50htz (can`t remember the model) telly and have been experiencing some problems with the picture. the best way to describe it, is that at times there is like a shadow on the picture. it follows the movement of text on the screen, or with bright colours it is very noticable. if somebody moves their arm up and down, for instance, there is a shadow line the width of the screen that follows the movement. it is only noticable at certain points but enough to ruin the viewing experience.
    i have since swapped connections around so that my sky box is going to the rgb scart in the telly and the dvd player to av2. the dvd works fine in av2, but then again sky seems to work fine in the rgb scart!
    does anyone have any idea what could be causing this?
    thanks
  2. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    anyone.............?:)
